No problem, os is windows 7 64bit and I installed the 64bit version.
Just tried the 64bit version on 7 and it crashes unless you run as admin.
Very odd, I hadn't got any of these problem on my main system and development VM.
Can you give the portable version a look at and see if it does the same thing:
http://sinvise.net/home/projects/downloads/software/shutdown-timer/portable/26-shutdown-timer-2
Yes, same thing happens.
Same issue and same error codes in the event viewer. 64bit version portable on 7 x64
You're killing my Windows reliability score you know![]()
I found the problem to be that it needs to be called Shutdown Timer.exe and nothing else.
Suggestion..
Are you running with UAC disabled, and these guys running with it enabled?
Can you give me a link to the portable version just so I can check I'm using the right one?
