Had to use an 8 pin extension, due to the backplate on the board and the cpu cooler bracket, i couldnt get the cable through the cut out. On your system paradigm, what did you do regarding the front fans, mine are temporarily connected to the motherboard, right on the edge next to the hdd cages (one near bottom and one near top) going to replace the stock fans and fit a 5.25 bay fan controller.
Probably just make them out in this pic.
