- 23 Nov 2009
- North Leicestershire
It arrived have everything set-up and running just finalizing drivers and proggys before i post any views on the system.
Nice one mate let us know how you get on!
But that looks like a bloody huge box for a PSU, unless it's just the picture
What's full spec list in the end?
Your X4 955BE is a C3 stepping??
You've put it all into a case that you already have Jimmy?
Agreed Technics...would like to hear your views on the NEW 333 version MB and it's OC capabilties Jimmy
Well tbh the motherboard is awesome.
lots of features, more bios options than i can bare to look at,
only did a small overclock to start adjusted ht and cpu-nb to 2200mhz and changed the multi to 18x whcih gave me 3.6Ghz
changed the ram settings to 1600mhz (which is very easy on this mobo) with 8-8-8-24 timing at 1.65 volt
quick super pi 1million took 19 seconds and 8million took 3minutes 59seconds
a 45 minute blast on prime 95 got me a highest temp reading of 47degrees using the thermolab baram and 1 apache fan (another fan is coming next week to use in push pull)
only thing i noticed up to now is that increasing the FSB above 210Mhz results in firefox not opening but that is easily combated with using the multi.
Not a bad start for a new build and especially considering my overclocking experience is quite limited with this set-up.
will post more later when i've got the cable management finished.
