Cheers Russinating, might be me but the link seems bust.
No, that is Opera's fault. It loads via it's own proxy to speed things up, but compresses images as a result.
View a page in IE and images will be their normal size and quality.
Have switched to Virgin from Tmobile and as they use the same networks both suffer the image compression, it doesnt matter what browser you use it still does it. If I tether the phone and use a laptop for browsing with firefox it still compresses the image.
Yeah I still get that problem with Opera Turbo disabled and in IE, so its definately the image proxy thats making it look bad. According to this thread http://www.3g.co.uk/3GForum/showthread.php?t=44215 if you are a T-Mobile user it can be disabled. Can Virgin users do it too?
I think I will upgrade the ROM. I am still on the standard one! A few bugs are now really annoying me..
Let me know how it goes guys and I may well join you.
Not flashed a new ROM...yet. But do you have to reinstall everything again every time you do? Including re-doing all settings? That would really put me off.
