Battlefield BC2 looking dam sweet
Use the server on the right side of the screen instead of form the multiplayer, doesnt CTD for me that way, but when i dont get the 'connection to game server has been lost, please check your netowrk settings' and am able to get in and start loading the map i seem to get kicked straight after it loads.
This is interesting. On ea's forums it says to play now before you login, then it logs you in automatically. So i did that and it appeared to load the map before telling me it had a connection error. But it also appeared to kill all my RAM at the same time:
LOL!
Just equate a beta to say a toddler, and the objective is to run. Sure the toddler can just about do it sometimes, they are working towards being able to run all the time without falling over.
You wouldn't get your knickers in a twist and return a toddler to the hospital if it couldn't run straight away. I think some people don't understand what the FIRST NIGHT of beta is.
me on a quad and playing like 99 percent of games ran smooth as silk .
i used the server browser and the join game thingy.
Yes, of course it is acceptable, that's the whole point of a beta version after all, to allow these issues to show up and get fixed.
What were you expecting from a beta, a totally stable, completely playable, balanced game? :confused:
Of course not, the ability to join the game say 70% of the time would have been nice. I only managed one connect out of around 20 attempts.
I find it hard to believe that the CTD issue wasn't showing during in house testing.
Games are getting poorer in my eyes as the years go on, maybe I'm growing out of them I dunno, just get tired with this endless crap and simply don't get excited about any games anymore, there all just rehashes of games year in year out.
Seriously having real issues. Everything on max 1900x1200... 50 FPS fine, then bang every couple of seconds 25 fps and feels like I freeze. Tried putting on low and some crap settings, exactly the same :/ wtf. Also flashing water :(
They didn't have 100,000 clients to try to connect at once. To be fair, if you don't want to buy it, then don't. I think most of us don't want to hear you whinge about it.
I have tried play now before logging in, it then logs me in as normal and gives me the normal error when going play now.
Trying a reinstall
Well ultimately it depends what is causing the issues as to whether they should have been sorted or not but seeing as you don't know that, frankly what you believe should have been sorted is irrelevant.
I honestly don't get what some people were expecting when playing the first release beta test of a game, of course it will be riddled with issues, that is the entire point :confused:
If you are 'tired with this endless crap' what on earth possessed you to participate in a test of one?
It appears most people are whinging lol.
I want post about PC games anymore incase I offend anyone with my opinions.
LAck of anything else to play I guess, I did the same with 2142 beta, cancelled my pre-order and then bought the game a year later when it was actually playable.
I guess I need a new hobby.
LOL!
dont be so retarded BETA should be working with maybe balance issues and minor bugs.
ALPHA is a toddler falling over.
In Alpha this shouldnt happen let alone beta
