CORSAIR EXTREME BUNDLE KIT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
Due to popular demand of the Corsair Obsidian 800D Case and H50-1 Watercooling CPU Kit, we have teamed up with Corsair to bring you the Corsair Extreme Performance Bundle including the HX 650W Modular Power Supply for just £329.99 Inc. VAT. With a massive saving of £38.97 Inc. VAT, this kit provides excellent value for money and the latest performance hardware you need to get your high-end system up and running.
Corsair Performance Bundle @ £329.99 inc VAT
Case - Corsair Obsidian 800D
The Obsidian Series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring. A windowed side panel makes it easy to show off your work.
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays, 4 x 3.5" SATA Hot Swappable Bays, 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included) and 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
PSU - Corsair HX 650W Modular Power Supply
The Corsair Professional HX650W is ideal for performance enthusiasts for whom consistent delivery of rated power output is essential. It delivers continuous rated power at ambient temperatures of up to 50° C. An intelligent fan speed system regulates the ultra-quiet 120mm double ball bearing fan. 105° C rated industrial-grade capacitors provide uncompromised performance and reliability. It’s fully compatible with the ATX12V v2.2 and EPS12V 2.91 standards and backward compatible with ATX12V 2.01 systems.
- Guaranteed to sustain its full rated wattage at an ambient temperature of 50°C
- Up to 85% energy-efficiency under real-world load conditions*
- Single +12V rail design providing up to 52A
- Multi-GPU ready
- Active Power Factor Correction (PFC) with PF value of 0.99
- Supports ATX12V 2.2 and EPS12V 2.91 standards. Backwards compatible with ATX12V 2.01
- 5 Year Warranty
CPU WATER-COOLER - H50-1 CPU Cooler
The Corsair Cooling Hydro Series H50 CPU Cooler gives you the power of liquid cooling in a compact, easy-to-install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
- Supports LGA775, 1156, 1366, AM2, AM2+ & AM3
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Only £329.99 inc VAT.
ORDER NOW
Very nice kit. That case is awesome, quality PSU and a popular CPU cooler.
Just a thought - people with the cash to splash on a £210 case might be also putting a very powerful spec in it, and so may want a more powerful PSU. Perhaps your experience has shown you otherwise?
take the H-50 out bung the PSU upto the 850w Corsair and u got urself a customer!
ive had the 800D and the 850w version in my basket for about a month :D
I would certainly agree with that 650w would be a little low...:) Was aiming for the 850W version as well.
Give me till tomorrow, speaking to Corsair now. ;)
Please do let me know as I am serious consider to take this offer (bundle) only if corsair agree to have Corsair HX 750W Modular Power Supply or more ! as 650W isn't enough ! Nice one OCUK for a great deal with Corsair and good luck :)
Do you want it with or without the H50-1?
Awww man, you have to be kidding me.
Although i'm sure it was a while ago i got that power supply and was looking at the case (decided not to in the end)...and about to buy the watercooling :(
Always the way!
Leave this bundle as it is and make another one that will the have same case + 850W PSU and no cooler. Will be nice option to buy that to go with one of the overclocked bundles!
Corsair Extreme Bundle @ £369.98 inc VAT
PSU - Corsair HX 850W Modular Power Supply
Corsair Professional Series power supplies set a new standard by which all premium PSUs must be judged. Designed and engineered using cutting-edge technology, each Corsair Professional Series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiasts demand.
- Enhanced modular flexible cables enable easier cable routing and increased airflow in the system
- Guaranteed to deliver rated specifications at 50ºC.
- Double forward switching circuitry design offers high efficiency, up to 90% under typical load range
- Ultra quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components
- 5-Year Warranty
- Two-year warranty
Only £369.98 inc VAT.
ORDER NOW
