@Phoenix
Less sarcasm from you Phoenix. Re-read my post, including the quote. I am responding to Wayne saying he hopes the amd will be quicker under some circumstances, with an argument to the effect that I can't think of a single example where the amd could be quicker than the intel.
I don't know how I can make the line regarding graphics cards clearer. The only circumstance in which the amd can be considered quicker is if it's combined with a better graphics card than the x58 system, and you only judge it by gaming performance.
I'm hugely irritated that you were too thick to grasp this the first time around, and by how you expressed your incomprehension.
@Pieman the flaw in what you're saying is that Wayne is repeatedly steering this away from a discussion on what system is the best value for money by refusing to permit discussion of any other processors. If the cheaper system is good enough then that clearly makes more sense. Restricting the discussion to Intel high end and AMD mid end while forbidding discussion of the i3 in particular prevents any further conclusions being made however.
I tend to agree with you in part, but what wayne is showing is cost disparity between lowend and high end components versus performance, ie: is it worth it? ignore the other combinations available and just using the two systems quoted, what is being demonstrated is the fact that you don't get twice the performance for twice the cost, you might get say, 20%-30% increase,( I don't know the exact figure but I'm sure some person might hazard a more accurate figure/s) for a 100% increase in cost. Hence my own analogy with the Cray super computer and the X4, course the cray will be a darn sight quicker, but would you consider it worth the increased cost?
Wether ppl here think that wayne is justified in only allowing the two sets of components being used that were quoted in the original post is a moot point, its his post and he can do what he likes with it as it were.
And like I said in me previous post, what about comparing cost versus performance between i3 and i7? I bet that would raise a few eyebrows.
. . . If you think about it for a bit you will see a bit better hopefully . . . somebody should have gone off straight away and done that without expecting me to be able to collate all the data which is stll only starting to come through now . . .
