The life of the H50 is 2 years
For further information regarding ****'s warranty procedure please click here [link removed]
Details
Duration: 120 months
Type: Return to base
RTB Period: 120 months
Details
Did you set it push/pull with 2 fans as this is important.
Now if they had the brains to put some bigger radiators on the thing, and longer cabling, things might get interesting.
BUT the H50 loses out consistently to the top end, cheaper air coolers- check the reviews, and there is a possibility of them failing or leaking that just isnt there with a static hunk of metal air cooler. (worst comes to worst you gotta replace a fan).
H50 is the future of high end cooling, as the Venomous X has shown people are having real difficulty taking air any further, but the design needs improving on.
It isn't the best price, risk, lifespan or performance wise- so why bother? - with the exact same kit I am using a lapped and pressure modded TRUE, and just cant get over 40 degrees C on stock.
Simples.
My H50 keeps my 920 sat at 27-31 idle and tops out at 58 @ 4ghz under prime . Currently sat back at stock though but undervolted as i need to tweak my OC more. Stock it sits 24-29 tops at 35 on load
Yeah thats what Im talking about - Stock speeds, no voltage changes, load temps peaking at 38.
At 3.8 my mega keeps its idle temps below 35.
ok so if you at all the reveiws all over the net they are wrong ? like i said im not on about idleing im on about LOAD... whats you load at 3.8 ?
I have just got rid of my H50-1 so i know what sort of temps and there is no way your going to get under 60c @ 4Ghz with that cooler.
That isnt what he was saying. Hes saying at STOCK speeds - thats 2.66GHz on a 920 D0.
My Setup hits 57 on its hottest core at 3.8GHz FULL LOAD.
Reviews/benchmarks etc are all well and good but theres a lot that affects the temps; eg thermal compound, application method, case airflow, fan static pressure, fan setup.
If you read what he says properly :
" My H50 keeps my 920 sat at 27-31 idle and tops out at 58 @ 4ghz under prime "
Where does it say stock.... ?????
My H50 keeps my 920 sat at 27-31 idle and tops out at 58 @ 4ghz under prime . Currently sat back at here stock though but undervolted as i need to tweak my OC more. here Stock it sits 24-29 tops at 35 on load
