To 0800 or to not
27 Nov 2004
North Beds
Hey guys,
if this could be turned into a poll that'd be great.
I'm just about to send a set of designs to the printers for business cards etc for my photography business. Last thing I need to decide is to use a Geographic number or an 0800 number. As Joe public, would having an 0800 number put any one here off calling a photographer if you needed their services? My website will have the geo too, so people who dont like 0800 ie from mobiles can call the 0161 number, and both will point at the same SIP phone so that's not an issue, it's PURELY public perception on the business card.
0800 to me looks more professional than a bog standard 0161 number, and also means people who have my card won't immediately dismiss me for a job in london due to a manchester code when I would probably still like to tender for it etc.....
Thoughts? Possibly a poll?
Cheers
Tom.
I say the 0800 number, will make you seem like a "bigger", professional and more established firm in my eyes.
If I saw the 0161 I would think you were running the business from your home. It wouldn't bother me too much if you were a local business, but being national get the 0800 number.
I know what 0207 and 0800 is, but I've never heard of 0161!?
I would assume that is the local area code for Manchester or something
edit: yep google confirms
The 0161 area code is for Manchester and surrounding area, United Kingdom.
The full number should be written like (0161) xxx xxxx OR +44 161 xxx xxxx.
Because people don't know what it is. I'm fine with the cost of running an 0800 number that doesnt bother me.
The majority of clients we deal with, including large multi-nationals. Seem to have 0207 and 0208 numbers. They certainly don't seem any less professional. In fact, as a business customer I would feel cautious if I had to deal with an 0800 number, I'd be worried I would be going through the same hoops as non-business customers.
To me 0800 number means endless waiting choose option 1,2,3 etc and never speaking to the same person twice.
On the other hand an 0800 may make you seem like a bigger company, which might put people who want that personal touch off.
how about an 0845 number?
5p from the users end roughly, but does look not bad.
as i say i don't care about the cost to me, my provider only charge me 2p a minute inbound for 0800....
I think i'll go for an 0800 and leave the 0161 number on my site
Can I ask who your provider is? Was looking a few weeks back and cheapest I could find was 8p per min for incoming calls on a 0800.
Thanks in Advance.
Telephone numbers are all designed for different purposes. Telephone companies talk of them as ‘products’ – they are not all equal.
Telephone numbers are also perceived differently by consumers. How they feel about a number and what they think it costs them to dial it, can radically affect what they think about your company and whether they will call you or not.
In short, they are part of your brand and image and they are not easily changed once chosen, so it’s important you consider the type of number to use carefully
Ofcom research tells us that:
1. Consumers know what 01 & 02 numbers (geographic numbers) are and believe them to be the cheapest number to call
2. 64% of consumers know that 0800 are free to call
3. Consumers think there is little difference in cost of calling 0844, 0845, 0870, 0871
4. Consumers always overestimate how much all types of calls cost.
5. Consumers are less likely to call numbers that they perceive to be more expensive to call and/or are unfamiliar to them.
6. 65%-78% of consumers either won’t call, are unlikely to call, telephone numbers used in adverts - even for products they are interested in - if they use these numbers: 0845 (65%), mobile (70%), 0870 (73%), 0844 (76%), 0871 (78%).
Source: http://www.ofcom.org.uk/consult/condocs/numberingreview/research/
If you read no further than this; normally, it’s best to choose an 01 or 02 number for your business. Additionally an 0800 should be considered if you actively need customers to call you or are running advertising campaigns.
Unless you have a specialised reason for choosing any other type – don’t.
01 & 02 Geographic – the normal, general purpose, everyday telephone number. Geographic numbers show your location; 020 7, 020 8 and now 020 3, is London, 01273 Brighton, 0151 Liverpool etc. Calls to these numbers from BT landlines used to be charged at either local or national rates depending on where the caller was but now it’s one charge, 3p per minute (day), regardless.
These numbers are universally understood and should be your first choice for a normal businesses number. Their sole disadvantage is that they cannot be taken with you if you move outside the area of the telephone exchange they are connected to. (However, this is no longer a restriction for VoIP geographic numbers which can be taken anywhere without needing to tell your provider; even abroad.)
They are the only type of number that can be reliably dialled from anywhere in the world.
Importantly, 01 and 02 numbers are included as ‘free’ to dial in mobile contract packages.
0800 – Freephone numbers are used for marketing or for sales lines where the strategy is to attract customers to call you. Most people (64%) know they are free to call so they are a good marketing tool. They are often used for short term marketing campaigns; different numbers can be used per advert to help tracking and calculating the relative success of different campaigns.
Costs to you. The numbers retail at a range of prices from £5 per month upwards. Look out for set-up charges and minimum usage charges. As the call is free to the caller, the number owner gets charged for the incoming call usually between 3p and 6p per minute.
0800 is a well understood number but because it is non-geographic ie not tied to your local telephone exchange, you can take it anywhere in the UK when you move. For this reason it is sometimes marketed to you as a number for life.
A major downside is that they are NOT free to call from mobiles and may not be called from outside the UK.
0808 numbers are the same as 0800 and introduced because the 0800 range is running out – these are less useful as people don’t necessarily know they are free to call.
0845 was introduced as a Lo-Call number as callers are charged at local rates (when called from landlines) no matter where they are. Unfortunately, there is no longer a different charge for local and national calls to ordinary geographic numbers so the marketing distinction has been lost.
They are however cheaper to call than geographic numbers 2p rather than 3p pm (day). I doubt that anyone knows this – did you?
Ofcom research tells us that they are generally thought to cost the same as dialling 0870.
BT no longer really promote these numbers and they have been undermined by the growth of mobile as they are not included in mobiles inclusive calling minutes and charged for at various rates, always more than a national call.
Being non-geographic they have the advantage of moving with you if you move. They are often not dial-able from abroad.
0844 is a revenue sharing number ie the owner of the number - usually the service provider – gets a small proportion of the income generated from the call.
They are a confusing number group as it is necessary to know the 5th digit to know what the call charge is.
Unless you have a specialised service, don’t use them.
0870 were introduced as low cost, revenue sharing numbers for companies providing a service to their callers such as a help line.
In January 2008 the revenue share element will be removed by Ofcom and the call charge to the customer reduced to the cost of a standard national call rate..
As a result, 0870, which was often offered as a free number to small businesses will be abandoned by the industry.
0871 is similar to 0870 but with higher call charges. They pay a revenue share too but are now regulated by ICSTIS and if you use them you are obliged to notify the customer of the cost of the call which rules them out for normal use.
As true value added services though, they have their place – but please do not even consider them as a normal ‘contact me’ number.
They are non-geographic so can move with you but often can’t be called from abroad. Calls from mobiles can be charged at any rate at all.
09xxx are real premium numbers with rates that can be £1+ per minute and are designed for valuable information services like pornography. To get one you need to apply the ICSTIS.
Useful web sites:
http://www.icstis.org.uk/
www.ofcom.org.uk
Cost of calls to specialised numbers:
http://www.downloads.bt.com/pricing/SpecialisedNos.pdf
Area code look up table
http://www.ukphoneinfo.com/section/home/introduction.shtml
International Telephone number wiki
http://en.wikipedia.org/wiki/International_dialling_codes
How to get a telephone number for your business
http://www.voipfone.co.uk/How_to_Get_A_Telephone_Number_For_Your_Business.php
Source: http://www.ukbusinessforums.co.uk/forums/showthread.php?t=46850 - posted by www.voipfone.co.uk
If you do choose 0800 i would be inclined to put "freephone - 0800 xxxxxxxx" on your business card, just for the numpties who might be scared to call :) Though it might spoil the look of your card depending on which way you plan on having it.
