Battlefield BC2 looking dam sweet
Just played on a hardcore server and it's a lot better game!
One or two issues though like the mounted machine guns not having a proper ironsight so it's nearly impossible to aim properly.
Same applies for the side guns in the Bradley.
Is there an official beta forum? I want to put my views across...
How did you find a hardcore server??
You think that will make much difference ?
yes it will . this game is a cpu whore just like gta
your cpu is well known for high clocks your not even touching it.
i reckon youd get another 10-15 fps at 3.5 and that would should be a cake walk for a q9550
He says the ping goes higher in dx10 though, that's just not right overlocking the cpu an't gonna help. Besides he has one of the best gfx cards you can buy. If it can be run at playable fps with a 4870 and dual core in dx10, it can defo run with his system.
yes he has a good card but i bet my tophat that he gets at least another 10-15 fps from releasing any bottleneck from the cpu.
reasonable cards want at least a 3 gig cpu and he has a fast one plus the game is a cpu whore so i would go over recommend plus his cpu will do it easy.
most do 4 if you know what your doing or more.
3.5 he could do in minutes if he has the cooling and i guarentee it will run a lot better.
sometimes if your cpu gets overloaded your ping shoots up like this
I dont mind OCing it it it will help out, its under water anyway. Few things i'm going to try though is.
A. 9.12 Hotfix drivers
B. adding a +fullproc startup switch on the shortcut to force use of 4 cores.
C. This insane suggestion
ea forums said:
Yeah it is rather broken right now, we are working on it (Friend system)
The 'high' texture detail level isn't implemented in #BFBC PC beta. Is in the final release so will be a bit sharper
We plan to add support for it yes, can't say for which patch/release yet until it is fully implemented though (FOV)
Yes we plan to update the beta with a few more patches
Who cares? Having a few PS3 files doesn't affect the gameplay experience on PC! (In regard to the morons finding references to PS3 and 360 in hex editors)
WIN
http://forum.ea.com/eaforum/posts/list/385265.page;jsessionid=BEE43F4E632BE937B0723B45DA171E88
http://blogs.amd.com/how-to/2009/11/16/11-days-of-directx®-11-day-six-dice/ <-- interesting intv RE DX 11 and frostbite engine
