Hi All,
Well following on from Easy Riders superb effort at a cinema room. I'm also going to be having a go.
The wife refuses to let me have a big TV / 5.1 cinema set up in the living room, so I'm going to change my current study over to be a Study / Home Cinema Room.
So I thought I'd post up my ideas here and get the community help on the build.
The hope is to start this build at the beginning of March, with it being completed by the end of April.
My room isn't as big as easy's as it is 333cm * 328cm.
The requirements are
Ability to have nice Oak desk, have one already in mind
New Office chair
2 seater recliner sofa
Built in Oak bookcase on one wall
Ability to hang 3 * 24" Dell monitors on wall for triple head gaming.
Projector / Screen or LCD / Plasma TV on wall for cinema experience
5.1 or 7.1 speaker system (think 5.1 will be enough)
Somewhere to store gaming case (Antec P900)
Somewhere to store Home Server (Thermaltake Tsunami Dream)
Printer shelf (probably on the Oak Bookcase)
The build plan is
remove all current equipment and chase walls for cabling, HDMI, speakers etc
Put in new power sockets (as only 2 * 2 sockets at present)
Sand back floor (currently stripped pine floor boards) and re-varnish
Plaster wall and ceiling
re-paint room
set up all equipment
and then there will be one happy Taff.
I'll post below the my basic plan at present as well as pictures of the room as it is currently.
So the questions I'll need help with
1) I'm going to hang my 3 * Dells on the wall above the desk using normal LCD mounting brackets, but do I then put a large 42"/50" LCD plasma above them, with ability maybe to use as 4th monitor or do I ut a projector and screen in so screen, when down covers 3 * dells, something like a 77" screen.
2) Do I install Sky into this room, and if so how best to do it, Skyt multi room via PC, or sky box.
3) If I go for projector, How long can you run a HDMI cable for, is there a limit? As I think I'll need one about 6m to reach from where Sky box/PC is to where projector will be.
Then the questions follow,
If I go for a LCD / Plasma - What ones?
If I go for projector / screen - What ones?
Budget approx £1,000 for the screen set up
Note : Room is south facing so get a lot of sun through south facing window.
For my Dells, Should I just go for basic flat wall hangers, or should I go with flexible arms?
What sound system, currently have pc running basic 5.1 creative set up, and also have a nice old sony set up (in attic). Possible budget for this item £300.
Will probably source 2 seater recliner sofa from somewhere like DFS.
Next Post Will contain the current WIP plan.
Taff
New Office chair
The build plan is
re-paint room
Taff
