Drunken computers
16 Jul 2009
Has anybody ever built a computer inside a beer fridge? Possible?
I'm off to google it now, but was interested if anyone here had any direct experiences.
I don't know a whole lot about it but from what I've read the compressors aren't built to deal with constantly being on...so as above it would burn out.
Beer fridges simply aren't designed for that volume of heat anyhow... they are designed to reduce things a little from room temp.
I have seen this done somewhere before, may have been a freezer though. The cold produced by the fridge is nowhere near enough to cool the system. You may be able to make a partition using acrylic, build your system in that, and then use a liquid cooling system and put your radiator in the fridge. It will still be expensive and not that good though.
Oh well, another dream dies! I have neither the budget or the technical knowledge to attempt anything like what I suggested. I was just curious.
People should keep this going merely to test ingenuity though. I'm sure someone out there could develop something, whether it's efficient or not....
Lol submerged computers weigh extraordinary amounts but I guess you don't need to worry about dust lol
Spend enough time on XS and you start to form the idea that phase cooling is extensively used. It works well. Generally the only cheap sub ambient cooling I know of is a modified air conditioner or a beer chiller, the type which deals with cooling tap beer in pubs. The latter can be had for about £100 and works astonishingly well, someone on here is using one at present. Peltiers look really cheap until you realise you need at least half a dozen of the ceramics, and see the price of the cold plates and of the power supplies.
