How long have you had it installed, have you installed multiple programs, is your taskbar cluttered or clean?
I've had no problems with my Windows 7 install, it always says 6Gb ram.
Your OS may restrict your memory?
Go to -Administrative tools.
Open - System Configuration.
Click the tab saying - Boot.
Then - Advanced Options.
Top right it says Maximum Memory, make sure the box at the left of the number is unticked, if its not, then I can't help any further![]()
Do you have any desktop gadgets open?
Search Indexing?
