carpet toothpaste stain removal?
Permabanned
22 Jan 2010
ok mock me if you must.
i dropped a coal onto the floor (creamish brown carpet) and it burnt a 1cm diameter hole in it. i found some replacement carpet and like an idiot used toothpaste to glue it in.
it didnt work and now i have a white stain. i have superglu so i will use that to put the carpet this time in the hole, but itll look weird in a middle of white. i have vanish spray but it didnt work, and made the white stand out more. anythign i can do?
if not i (deservedly so) will loose a £300 security deposit in july :(
lol, bad crack.
£300 deposit for something so minor, how big is the room with carpet etc?
Get a rug or something and cross your fingers.
Some landlords dont care about the property since its not their home, we stuck a door back together and filled in the gaps with cardboard dipped in a mucky puddle from where someones food had gone through the door whilst trying to kick it open.. :)
Theres hope!
haha atleast ocuk can make me laugh :D
no its not a troll sadly, and our landlord is a letting ageancy, and although my housemates are living here next year, i am being kicked out and replaced by a stoner because of this, so i need to fix it before i leave.
lol toothpaste to glue it in?
That should have worked! Did you use colgate or aquafresh?
On a serious note I think jizz would have worked better ;)
You're getting kicked out because you made a hole in the carpet?
Oh and why toothpaste?
Your housemates are kicking you our for burning the carpet? :confused:
They sound like dicks, sabotage their rooms (conceal some shrimp in them) before you leave.
Try the Vanish carpet powerfoam mousse, I have light coloured carpets and three young boys. Gets most things out, if you work it in a bit.
thank you, will buy asap, and yes they did. they still said i was am very close mate but they are replacing me, with a stoneer no less.
lovely people. now leaving me to get a lot more expensive 2 bed, as the uni wont let me go into halls.
They are replacing you with a stoner!! :eek::eek::eek::eek:
A person who will drop hot rocks all over the furniture and carpet causing loads of burns which could lead to the place burning down.
If this is true then get your stuff out of there and tell them to f off!!
You are better off without mates like that.
Then again....
Is this the first time that you have peeved them off??
If it is part of a long running thing(s) and they have had enough of you then.....
Maybe you dropped one too many hot rocks from your hash pipe \ spliff onto their carpet saying it was a piece if coal.
In that case.......
I think you should jog on. :D
nop first time. plus its not hash, its shisha lol. well one of them hates shisha as it was and this was the straw that broke his back. the other two follow what he says, though they bitch about his to me a lot. and the thing was we were due a 3 bed house, till he needed a house, so we decided to get a 4 bed, and now he wants me out.
lol istn hash illegal though? this is just flavoured tobacco and mollases.
no lol, not english thank god, engineering.
