RUF CTR3
18 Oct 2002
Nordschleife
Spotted from another forum but its the car I'll be filming at the end of the month and a full feature in the summer :D
The CTR 3 was presented in April 2007 at the grand opening of the new RUF facility in Bahrain. While the first two CTR generations still had their engines in the rear, the new CTR 3 has a mid engine design. However, one thing that the CTR 3 has in common with its two predecessors is that it is a pure driving machine. The CTR 3 is made to involve the driver in the driving experience.
The mid engine design provides exceptional balance and agile handling, while the longer wheel base provides better driving stability at high speed. The body of the CTR 3 is a completely new development which is not based on any existing mid engine concept. It is aerodynamically designed for high speed. The body is constructed in steel, aluminium and Kevlar-carbon. Galvanized steel is used for the front structure and the passenger compartment. The engine and transmission are fixed in a space frame and modular tubular frame construction. The passenger compartment is protected by the latest version of the famous RUF integrated rollcage which is integrated into the A pillar and tube frame. The doors, with integrated side impact protection beams, and the front hood are made of aluminium. The body shell is made of Kevlar-carbon composite.
The concept of this classic sports car was maturing in Alois Ruf's head for a long time. Together with his design and engineering team he now realized this idea. RUF has 30 years of experience with turbo charged boxer engines. The CTR 3's twin turbo charged 3.8 litre flat six cylinder engine has an output of 700 hp at 7,000 rpm. The maximum torque is 657 ft/lbs at 4,000 rpm. The maximum torque is 657 ft/lbs at 4,000 rpm. This engine design combines a compact construction with high performance. Each turbo charger is provided with an intercooler which is placed in front of each rear wheel.
The sequential shift 6 speed transmission in the CTR 3 is a new design and is transversally mounted. It can manage torque up to 855 ft/lbs. A shift indicator on the dashboard shows the gear in use. A limited slip differential is provided to maximize performance. The sport suspension is designed for high level driving dynamics and safety. The front axles use McPherson struts and an anti-roll bar. The rear axles utilize motor sport technology with horizontal coil over shock absorbers fixed over pushrods connected to the wheel carriers.
The brake system is designed to match the high performance of the engine and suspension. Both front and rear axles utilize 6 piston fixed light alloy callipers and ventilated, cross drilled ceramic composite discs. Each brake disc is 380 mm in diameter. A specially designed Bosch anti-lock braking system is standard.
The CTR 3 rolls on forged aluminium wheels with centre lock. At the front 255/35 ZR 19'' tyres are mounted on 8.5'' x 19'' wheels, while at the rear 335/30 ZR 20'' tyres are mounted on 12.5'' x 20'' wheel.
The interior can be designed to the customer's taste, from a functional a functional light weight finish to sporty luxury finish with leather and alcantara. The aluminium gear shirt lever for the sequential shirt transmission is a central unit to the interior. In addition, the 260 mph speedometer shows the driver that the CTR 3 is made for high performance.
The lightweight construction allows for an empty weight (according to DIN) of 3,086 lbs. The result is a power to weight ratio of only 4.4 lbs per hp.
The performance of the CTR 3 is incredible. The acceleration from 0-100 kilometres per hour (62 mph) takes only 3.2 seconds. The maximum speed is 375 kph (235mph).
PICTURES 1234567
TECHNOLOGY Power
515 kW (700 bhp)
at 7,600 rpm
max. Torque
890 Nm
at 4,000 rpm
Displacement
3,746 cm³
Performance
0-62 mph (0-100 kph) in 3.2 seconds
0-125 mph (0-200 kph) in 9.6 seconds
Top speed
234 mph (375 kph) - dependent on the gear ratios
Fuel consumption:
urban (l) 20,0
non-urban (l) 9,9
combined (l) 13,5
CO 2 emissions (g/kg) 311
Any t'interior shots? :)
Not at the moment :(
Looks fantastic, nice one matey.
Hows the whole man with a camera thing coming along?
Very good at the moment, things were massive for me in 2009 and 2010 have started with a bang! Hoping to get a chance to do something special at the end of the year and Its the WRC stuff that will give me a chance to go Pro I think.
Niiiice! Although the rear axle position does make it look a little odd, but I bet its a riot to drive.
Loving the V12 plate on the RR. My boss has a V8 and a V12 plate but on the respective cars :D
