Man of Honour
- 1 Aug 2004
- Tyneside
I just love the DH Mosquito.
Awesome plane.
Awesome plane.
Had a rummage earlier and found these pics:
I made these a few years ago along with the F4 Phantom I posted a pic of earlier in the thread. Thinking about it, I must have made hundreds since 1986 when I first started.
A mixture of tamiya and hasegawa I think, 1.48 scale, finished in xtracolor paint and humbrol matt varnish
nooo not this thread again! delete! it makes me want to spend money![]()
They are fabulous! Would you mind listing here how you went about making them look as good as they do? Like how did you make the panel lines so defined? And I would love that mossie! It's £120 though!! I have a magazine here which is going through the build of the very model. It looks stunning.
) I don't see any need meself, but other ppl here will probably have different ideas/techniques, procedures, etc.
Maybe I'm doing it wrong. I will have to practice.
Excellent looking Hurri, even though it sounds like you had a trial with it. What problems are you having with the pro-modeller wash ?
I realise its all trial and error and I'm happy with that, but this is the fourth model I have attempted with the pro wash. Same result. I wonder if I apply to much Klear initially..Thanks mate appreciate it! It has taken me quite some time if I'm honest. More time than I realised.. It's waiting days for the varnishes to dry really that's the worst part.
Yeah with regards the wash - I shake the bottle, stir it even, and apply it as per the video I've seen. I leave it for a while, then wipe it off with a damp tissue. It seems to leave a very obvious clay residue rather than emphasising the panel lines. It just looks generally dirty rather than the effect I have seen in photos and I cant understand how they achieve it. I did attempt pre-shading for the first time which was laughable - I then over-painted the camouflage which covered it all upI realise its all trial and error and I'm happy with that, but this is the fourth model I have attempted with the pro wash. Same result. I wonder if I apply to much Klear initially..
Edit: You can see in that first pic where i used the flash - look at the tail. That's the sort of thing I'm up against. I'm using the dark dirt wash.
Well I've semi-completed my first ever 1:32 model - Mk1 Hawker Hurricane. It was not the easiest model to start with. The instructions were pretty poor, and the wings supplied were for the MkII and not the MkI so I had some serious dremelling to do. I had quite a lot of cutting/filling to do and even now it isn't overly authentic but it's not bad for a first attempt. I tried to make it look legit, and used the proper colours. One problem I have though is weathering. I know it's subjective, but I can never really get the effect I desire. I have got some Pro modelling wash here and I just don't like itMaybe I'm doing it wrong. I will have to practice.
Christ not another one finished already !!!
Well my 1/32 Zero is about 90% finished and I have been using both Pro wash
as well as Klear without any major issues.
After I was happy with the paint ( i am still using a brush) i put a layer of
Klear on then weathered the panel lines.
I used a bit of kitchen roll to get rid but only slightly dampened it if the marks were not coming off easily.
I then sealed it with another coat of Klear.
Just got to weather the decals a bit (as I was scared that my panel lines
were going to fade if I put decals then another coat of Klear before the weathering) then I will put
another layer of Klear then finish with some Klear / Tamiya Matt combo to
finish.
How deep is your panel lines as I would have thought the light underside
would have came up nice ?
If it is any help, they both make diorama's now, however before they would create models of battleships and things. Myself have made a few but would have no idea to what extents you can go to with it...
