The columns buckled and provided minimal resistance for a brief period over several floors. Remember we do not have equipment attached to the building to analyse in nano seconds. The total fall ti9me was 40% larger than freefall time should have been.
We have gone through this all before. You would not even read the links I gave you.
Yes I can.
The time for free fall of wtc 1+2 was calculated at totally the wrong point, clearly after the building started collapsing.
Loose change also said WTC7 had minimal damage from wtc 1+2 collapse.
http://wtc.nist.gov/NCSTAR1/PDF/NCSTAR 1A.pdf p92
The debris did match teh plane at the pentagon. Looschange forgot to say airlines could have several different engine models fitted when purchased.
Misiles can not cut down lamp posts or push a 10 tone generator out the way.
So your taking that report as gospel? and the point loosechange made was not of mismatching parts, more the fact there didnt even appear to of been a plane there in the first place, which is backed up by the photos taken just after the impact.
