Hmm interesting. Now seeing as it is only a trial version, can the standard WM version be downloaded if one is planning to buy it anyway? What is the reason for "cooking" it into the official rom?
Good news, it works. If you have alraedy purchased, download from here http://www.alk.eu.com/buynow/eu_download.asp and follow the instructions (extract zip and copy>paste the two folders to the memory card, reboot after install)
This copy will not work as a trial, you need the key for it to work.
I think it is stuck to the official rom as the trial is directly linked with the htc device, the trial is not available to use otherwise and co pilot probably don't want it to be easy to copy and share.
I've yet to fully test the software so won't say its working perfectly, will post back if there are problems.
@ Russ- I've ordered one of those cheap car mount kits, cheers for the heads up
