Wprime 2.2
Permabanned
19 Oct 2009
Lets see if this one is bugged to death
Dont forget CPU clock speed and what CPU if your pic is to small. O and thread count :)
Saved a spot for you mate, dont let us down :)
^^^^Scrapped ^^^^
Running 2 threads, not overclocked on my three year old laptop :) Edit if that can't be seen its 57.563 seconds. Clocked at 1.66Ghz
Woot! Wanna see more dual cores on there to see how mine stands up against newer ones (ie i3's).
running 1 thread
A bit "Presumptious" may be Danny :D
Especially as 2.02 is even more "Bugged" than 2.01 :)
None of my rigs will run 2.02 unless i press the "Shift" key to disable the the look for hardware. By the looks of a lot of the submissions so far, other peeps may well be having the same issue.
Of course, the only version that is acceptable on HwBot itself, is 1.55 anyway. Why not just run with that ?
Ok, I think somethings seriously wrong with mine, its just got a time of 13 seconds for an i7 running stock. When last time my CPU got 6. something seconds? Can anyone shed any light on this?
Edit, can my score have the clock speed at 1.66ghz? Thanks.
Just ran it again, with every unneeded process terminated. Result below, using the same frequency. 3 threads.
Mine is the same unless you give it 2 mins at least to sort its head out.
As for 1.55 will start one later . just with Mrs Danny atm. You know what its like.
