Blu-ray is far, far, far superior to DVD. People must have severe eye problems if they can't notice that.
I think stockhausen is either trolling
You can only bitstream TrueHD audio through HDMI as far as I know, it's also neater on the cables. HDMI is digital audio as well. Why wouldn't you want to use the same cable for both? Fair enough for a PC but everything else is better off with HDMI.
You don't say.
Although having said that, I'm cancelling my Sky HD as I really don't think the extra resolution makes all that much difference to my viewing pleasure.
CASH FOR GOLD! WE'LL BUY YOUR GOLD PLATED CABLE CONNECTORS IN EXCHANGE FOR CASH!i buy the gold plated audio cables and melt the gold down and sell it on the internet. :d
I received this cable the other day and plugged in it. I couldn't believe what I was hearing and feeling. My bowels started to shift and my tummy started to rumble. A few minutes later I made a big doodie all over myself. I can't believe it. This cable saved me from getting colonic irrigation. Wowee!
it depends though if you have a surround sound system with an amp then you have to run the hdmi and the audio cables seperate
The only thing I hate about expensive HDMI cables other than the price is the reviews that spout on about how a more expensive cable provides deeper blacks, better colours, better contrast etc which just simply isn't possible by changing a HDMI cable.
My £1.99 hdmi cable is ace![]()
Can i ask why people are posting comparison/pictures in jpeg format? Doesn't the compression jpeg use effect the quaility?
i go for £10ish area on HDMI cables, anything less then i am worried they will fall apart
