Didin't think of that. You mean something like this?If you are going to be putting in spacers then you will need to use thermal paste on each side. I'd be worried about them sliding out of place over time.
Could you not use thermal pads instead?
http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-CL&groupid=701&catid=57&subcat=27
Shame OC don't seem to have the game console sized ones!!! Incidentally, I'm using a citrus based cleaning solution on the CPU/GPU etc before applying the AS5 but it feels quite oily - I wonder if this effects anything?
