Catalyst 10.2
just in case anyone else has trifire using a 5970 and 5870, this is the procedure to disable ULPS
XTREMESYSTEMS said:
Have you guys tried turning off ULPS?
ULPS feature is enabled by default installing this driver, however you can edit this setting from windows registry,
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ass\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\EnableUlps
set 1 to enable ULPS
set 0 to disable ULPS
many users have another folders than 0000. I had 0000 and 0001. Some have had 0002, 0003 0004 etc. Where ever you find EnableUlps change it to 0 it fixed my lockups with everest and both gpus downclock to 157 with the 9.12 hotfix drivers
Well, just updated from the 10.1 hotix to the 10.2's, and this time I did a proper benchmark. Kinda.
Vantage test, settings to 'high' 1680x1050 res, second monitor connected but not doing anything.
10.1: three runs.
6091, 6140, 6075. Av = 6102
10.2:
6086, 6101, 6089. Av = 6092
A drop of 10 3dmarks roughly. Not something to worry about. Next month I'll add a couple more benchmarks.
10.3 beta leaks are out now too. Not sure whats in em, but they've definately got mobile support so they're recent. Might be worth comparing to those too :)
Everything seems fine for me with these drivers APART from MW2!
It played without crashing with previous drivers, now I'm getting a white screen every 15 mins or so.
Playing stalker and BC2 ok with 99% Gpu usage, MW2 only uses 65%!!
Anyone else having trouble like this?
Anyone getting crashing in BC2, try the 10.3 betas. Feedback has been rather good on them, and I've seen several comments on much improved BC2 performance.
I'm having something similar.I keep getting CTD after 15 or so mins too when playing any game so far.
