Ive been looking to play airsoft for ages, however the sites dont seem to be well published and im struggled to find somewhere in the midlands/derbyshire area
I wish you werent all southerners!
I need a northerner to take me to a skirmish!
Also, anyone got any ideas with my M4 problem?
It wont feed BBs properly. have it on full auto and hold the trigger, it will fire VERY intermittently
I love these threadsthere is always someone who can shoot 2 miles and take out an ants eye lol
It "may" be able to fire at that range but the target area will be size of a barn door . Non rifled ..low power ..plastic balls .. you do the maths but its not happening .
A decent ft air rifle (12ftlbs) would but at its limit at that range (lead pelets/rifled barrel etc ) so an airsoft with half the power certaintly aint with any kind of accuracy .
Persil
The subject of rifled barrels has been mentioned a few times. There are actually 'rifled' barrels for airsoft. Tanio Kobas make them. They've been seen to make quite a nice difference on guns between 300 and 350 FPS. Anything else and it either makes no difference, or makes it worse. The rifling spins the air around the BB. Not sure if you have to remove the hop though.
I've not heard of rifles barrels, but i have heard of some people using teardrop shaped bbs. Using that shape would mean you can't use the hop up, so that may be the type to use rifled barrels. Teardrops being very aerodynamic shapes in case you wondered.
How do they feed from the mag into the gun (special mags?) and in the correct orientation?
Hold it upside down so the BBs are forced by mavity, if that improves it something wrong with your mags/feed between the 2. If not might be a dodgy air seal or something?
Make sure you are using polished decent ammo that isn't dirty too.
Cheers, I'll give that a try at the weekend
Also, would a Shotgun Licence be a valid way to get round the VCRA?
My first time airsofting tomorrow, bit nervous.
Any tips?![]()
Don't get shot?
