Just wanted to check something on here before I go and loose all my data
Basically my Windows 7 RC runs out this (next) weekend so I need to transfer my data and programs to a new install. Perhaps there is an easier way of doing this. Ideally I wouldn't even need to reinstall the software but IIRC you can't do this with W7 to RC?
Here is a basic plan of what I hope to do.
Create a 200gb partition on my drive then transfer all my important documents to this alongside all the music and program installs can I then format the one partition and install a new copy of Windows 7 on the larger 800gb partition. Then I should be able to drag and drop the files from the small partition back to my new install.
I'll obviously be reinstalling most programs for a fresh install but I know with older games I used to run the installer then drag the files I have ATM in the program files and overwrite the 'new' game files to return to my original install. Does anyone know if this still works with my three main programs CS4, Lightroom 2.1 and Ableton 5 becuase I have them configured just how I need them.
It would've been nice to just use the external hdd, but ATM it's full of 3500 RAW files plus my documents.
Perhaps there is an easier way to do this? Perhaps it's now possible to migrate an install? Anyone got a good idea of what an ideal route to take would be?
.Basically my Windows 7 RC runs out this (next) weekend so I need to transfer my data and programs to a new install. Perhaps there is an easier way of doing this. Ideally I wouldn't even need to reinstall the software but IIRC you can't do this with W7 to RC?
