Can you record the conversation with the sales assistant when you ask for a refund please.
Ok well they make a noise and judder that's how they are useless, you know as if they are worn out. Such idiots on all these forums really gets on my nerves.![]()
Bosch wiper blades are meant to be highly recommended, I have read that they perform much better than cheaper ones.
Liam
Bosch and valeo tend to be what OEM use. Halfords blades are made by valeo but I don't know what they are like compared to branded valeo blades.
Refund on a perishable product is many lols too. The most I've done is swapped halfords crappy blades for more sturdy bosch ones if the customer pays the extra.
Halfords Staff always used to say that they were manufactured in exactly the same place as the el-cheapo ones. Whether or not this makes a difference I'm not sure but the for the cost of them I'd expect better.
How are they useless?
Even the cheapest, nastiest wipers move the water.![]()
Bosch Wipers are good at the start, but then start smearing really bad after just 3-4months. Really looking for a different make, but PIAA are really expensive and hard to find.
not really hard to find, camskill sell them. Hilariously over priced though.
