Best Case up to £120
2 Dec 2009
Bath
Looking at the Antec 1200 but not sure if there is a better deal. Looking for good airflow and space and don't mind it being slightly noisy.
Thanks,
Jake
If it was me I'd go for the the HAF932. But I don't think there is anything in it, the Antec 1200 is a great case, loads of space and great airflow.
Ok I've also been loong at the Coolermaster Dominator II Advanced like Superewza and I would like to know whats better about it?
Ok going for the Dominator II because I'll max out all the fans at some point with some Noctuas or some Akasa Apaches. Will be very, very cool then I reckon! :D
Air from all directions, Top, Bottom, Side, Front and Back.
Great help, thanks guys for making me look at this case! :P
Well ill be looking at cable management but no watercooling. Not for a year maybe. This is a large chunk of money im spending on this pc. So far comes to about a grand.
I really do like my Lancool Dragonlord KS-62. Lian Li design and manufacture yet very inexpensive. Really solid totally screw less design. Only downside is its steel (yet still not really heavy). Well that and the blue LED fans...
If you go with the KS58 you will not have the boyracer style, however the inside will be gray. I really like the all black finish...
Hmm I'm definitely getting the Dominator II because it saves a few quid from the Antec 1200 so i can buy a Rampage II Extreme. :p Also the Dominator has more cooling capability than the 1200 IMO. Thanks for suggestions though guys, much appreciated!
