SyncToy
20 Oct 2002
North West
When I attempt to sync with my NAS I get quite a few errors, I did some reading up and found it was an issue in previous versions but I use 2.1.
Any fixes?
Errors?
What NAS is it?
I'm not really a fan of general NAS, as the timing stamps that some use are incompatible with synctoy and other sync apps. I prefer using a lite windows machine as a fileserver
I'm about to try SyncBack for the first time, previously been a long term user of SyncToy x64 but this seems to have a lot more control and be better on resources to speed up backups.
Will see.....
Just to check though, this is the settings I need to Sync Sourc > Destination and delete anything on destination that doesn't exist on Source right?
In Synctoy it was called "Echo" synchronisation!
Looks OK to me.
Anything new on the left [source] is copied to the right [destination]. Anything on the right not on the left is deleted.
If you are still unsure test it with some dummy files.
Excellent stuff. I need to get a 2TB drive pair soon I think at this rate and a separate 500GB drive for the system images!
You might also like to take a look at FreeFileSync - it has many more features than the freeware version of Syncback, and it's also much faster (particularly over a network). :)
SyncBack worked perfectly!
My next Backup run I will try FreeFileSync!
Edit*
Wow FreeFileSync is awesome, just installed to see its UI/compare method etc, I shall uninstall SyncBack right now :)
Oh it's 64bit too :D
^ Now THAT is a compare report screen that shines above the rest!
