- 5 Aug 2003
- Essex
You wouldn't match anything already on their system so they'd think you are a new customer
Good point but I think they only check the name and address.
We need to make sure we process your order correctly
From the information provided, it appears you may already be a Sky TV customer, or have previously had Sky at this address. Please select one of the options below to continue:
Not quite, they'd look at the postcode and see that the house numbers match. If the surnames differed and there is no active sky account then they'd go ahead with it, if the surnames matched you'd have to say they moved out/you got divorced/widowed.
Hmm, well I have used a slightly different house number, but the surname, post code and landline number is the same.
You may get away with it, when is your install date?
This exact offer is freely available on Hotukdeals. Just go there. Massive thread about it there.
EDIT: Better yet, take the code: SUPR108334958542 (change the first 3 digits about to anything you want). Put it in here: http://offercode.sky.com/default.aspx
My only anger would be that there are never deals for existing customers!
