My Datsun
Nice family car you got there ;)
Get that camber sorted or it will eat tyres like there's no tomorrow, i do like these bit out of my budget though :(
Dude this car as i said before is the nuts. I am looking at it and it just gets me excited i nthe thought of having one.
I have never had a fast car, this is the playstation generations car after all :)
Finally the gearbox is a bit too notchy when cold between 1st and 2nd, so i'm double declutching in the mornings til it's warm so I want to do a fluid flush on it.
I've the same problem in the evo. I think mines attributed to Silkolene Syntrax, which although is recommended by Mr Opieoils, has seen problems in evo's for being "too slippy" when cold.
To slippy, how does that one work? Personally I think it's more to do with Mitsi's iffy gearboxes :p Mine doesn't like second at all when it's cold, same story I've heard from countless Mitsi owners of various models.
Not sure but it is a direct quote. Something about the oil not allowing the synchromeshes to work properly until up to temperature. I'll have a look for the thread.
Fantasticc car! I WILL own one of these before i have to get something sensible, or i may even take your example and use it as a family car :D
In my eyes this is still the coolest looking Skyline. Saw the advert on PH recently for it, whats the finish of the custom dial pods like/
lovely car mate, the gtr was on my shopping list before a mate broke my neck and wrote off my car haha, had to settle for the gts4 version instead afterwards, im running gtr running gear, brakes etc etc but with the rb20det engine in.
id definatley get rid of the hicas system, mines so much more predictable and quicker in the bends, theres a write up that you can take to a good garage to do the pipework for you :) il try and dig it out. also get a to9rque split controller fitted, gives you fine control of understeer/oversteer, theresd nothing worse than the 4wd reduceing the harder you push into a bend. in the wet this is my lifejacket lol :)
do you go to santa pod for the japshow at all?? would be great to see you there this year!
heres a quick piccy of mine, really miss the gtr bulges ><
Love them and kind of want one.
Remember going to look at an impreza a few years ago and the garage had one of these in.
The chap started it up and I soon forgot about the impreza, sounded awesome.
