prime95 query
Blend find more errors than the other two options, so if overclocking more than 1 component Blend is needed.
Your original question is answered by the above people.
Large FFT's is maximum heat, it says so.
I think the Blend produces the most all round test and thats the one i used for checking my OC was stable, i done a small FFT's after as thats more CPU intensive so tests that more, it leaves out the RAM, its also good to see if Blend is failing because of RAM or CPU.
Large FFT's is max heat and power consumption but i found the CPU got hotter running Blend.
