- 31 May 2006
- West London
Accidents happen, I'm sure you've messed up big time too
Personally I think coughing up £600 is quite reasonable.
your base unit isn't worth that second hand. And at worst the Case/optical/HHD/screen/keyboard/speakers etc are all fine.
If you have a mate's or work pc you can borrow - get an air duster to blow out any 'trapped' water, let the stuff dry and test each part.
As other have said it's most likely one or two bits that have died.
Just remember if you did it your self, you be in a worse situation.
Edit: For the replies I guess a lot of us have been in your situation one way or another.
And I understand the 'our money' issue - but sharing has many benifits, you 'might' be sharing an enjoyable evening for example
