I dunno what's all the hate about but temperature on those DOES make a difference.
Take for example my CPU will crash as soon as it gets 50-52c, doesn't matter if I run it at 3.6, 3.8 or 4.0
As long as I can keep it under 48-49c it's fine,  I see it hits 50-51 for 3sec = crash.
Stimulated few times to check by switching heating on/off and if my room gets hot then as soon as the CPU is loaded enough to hit 50c+ it's instant crash.
If I have heating off, or even more, keep the window open and then can keep CPU under 48-49c, even better 45-46 it can happily run prime for ages, then it jumps 2c up and crash.
Might be different for every CPU but seems like these things are very sensitive to temps.
Hence I guess the huge LN2 OCs, if I remember  well pII had the highest quad clock so far ? You just need to keep them very cool. Best is anything under 40c.
