Focus problem - Power loss / Speedo
24 Jul 2004
Having a problem with my Focus, after about 5 minutes of driving it starts doing random things ;
- Speedo drops to 0
- When drops it loses power so if/when I have to stop (put the clutch down) it usually stalls
Anyone have any ideas?
Thanks
Speedo - possibly the speed sensor on its way out?
Loss of power - spark plugs / HT leads or coil pack?
Liam
Forgot to mention that they happen at the same time. The speedo drops and I lose power. When the speedo comes back to life, the power comes back...
im sure this is pretty common, head over to ffoc and do a search, bet you find a few threads!
JanseyB will probably know the answer to this.
It's happened a couple times to me, but not recently.
Think it's something to do with the ECU and most dealerships will update the firmware iirc.
Thinking about it, it does sound ECU related. Have you tried disconnecting the battery for around half an hour? Let the ECU reset and this could possibly cure the problem?
Liam
Liam
No, but I will later on :) Come to think of it, it did happen after I got a new battery a few months back.
Vehicle speed sensor, plugs into the top of the diff and is made from cheese.
Yep. This is a definately a faulty VSS, common fault on the Mk1/.5 Focus. Part costs about £30 and can be replaced yourself, although it can be a pain to get to. Any good garage should be able to diagnose and fix it though.
The speed sensor will feed information to the ECU so could feasibly cause a stall - that would be my first guess
Same has happend to mine ( 2001 Y reg ) and its the speed sensor, getting it done on monday for £20 ( the mech owes me a favour as i fixed his pcs for nowt :p )
This will be the speed senser mine did the same, the loss of power I guess would be the ecu failing over into a fail safe mode, as the others said about a £70 garage fix.
Doesn't the standard Ford radio have a volume control that's linked to vehicle speed, from the same sensor? If the radio volume does odd things at the same time as the other odd things, that's the speed sensor for sure.
