- 3 Nov 2004
- UK
A multimeter, failing that then cpu-z. What you're seeing is a combination of vdrop + vdroop.
All depends on the chip...
Post some screenies if you are bothering to prime.
Got 3.8 on my 930 quite easily, stuck in stock volts and upped the qpi slightly.
IBT runs 5 passes fine, LinX runs 20 passes fine (both on max) and prime95 ran blend for 12 hours, and then blue screen with IRL not Less or equal. Anything to worry about or is it telling me I need more QPI? 12 hours prime I think is pretty stable.
How is it with RAM? Should I keep my RAM memory running near original frequency (1333mhz 7-7-7-20)? Currentely I run it at 1600mhz (9-9-9-24) with my i7 860@ 4.0 1.36V OC. (Ram is OCZ Platinum Dual Channel 1333mhz 8gb)
. Must be the 12 Gb then, changing my CPU would be pointless, I have good temps for air and have reseated it 3 times already to get them, so I really dont want to change either the CPU or Motherboard unless they fail.
1333mhz 7-7-7-20 would actually be quicker than 1600mhz 9-9-9-24 as you have less latency on the 1333mhz.
One of your cores has errored out there.
Primes should run for days.
Up the vcore a notch and turn off LLC in the bios and see if that helps
Why should prime run for days ?
Do you leave your computer running 24/7 with all cores maxed normally ?
If your overclock is what you want and stable with what you use your PC for..
Why waste the electricity..
Exactly what someone would say when they can't/don't know how to get their system stable.
Or you just don't understand what stable means.
