I'm running an X1900XT and generally it's playable @ 1680x1050 - Low quality settings, it does dip down to under 20fps though in certain areas.
What graphics card would you recommend upgrading too for 1680x1050 resolution? The rest of my system is fine![]()
Only prob is I continually get kicked by punkbuster lol.
You need to manually update PB and EA suggest deleting the BC2 Beta also from your HDD if you have that installed.
Makes no diff at all the problem is server side bug. Forums are full of people updating with no diff
Oh ok , it did for me though. I was getting kicked every time I joined a server and once I updated all was fine ...
Well I downloaded the latest client update from here and ran it . It looks for the location of your BC2 folder and then updates the PB folder for you .
One thing I noticed which I find really weird, is that you cant strafe when running, dunno if it bothers anyone else but it makes the game feel restricted IMO.
