- 16 Nov 2008
- West Midlands
my mate is getting this game. he has a 17" monitor and is thinking of buying a 5770 1gb. how many fps would he get maxed on with 4AA 16af in D11?
What does it manage if you use one 5870? that's very nice fps though.
Im getting 120-150 fps with 8AA 16AF HBAO on so maxed out at 1920x1200 to compare
+1
I'm getting around the same with same settings peeks at around 180 fps sometimes.
Seems these 5870's are now proving to be worth the investmant.
Must start to look into watercooling these cards, they get mighty hot at those settings.![]()
I'm getting between 60-80 fps on my setup at 1920x1080.
Last question I guess would be if it is at all possible to force it to use DX 9 under Windows 7?
Go to the folders My Documents->BFBC2
Go open settings.ini with notepad or some text editor.
Change value of DxVersion = Auto to DxVersion = 9
Save the ini file.
First result in google.![]()
