***HTC Magic Thread***
just download Android terminal emulator free from the market. Make sure you have root access.
Download Amon RA Recovery and make sure it is G version. Rename it to ballbag and stick it on your SD root.
Open terminal and type
SU
mount -a
flash_image recovery /sdcard/ballbag.img
..........DONE!!
Ballbag.img?! :D
How can I be sure I have root access? :p
Root access is denoted by the prompt, basically the end character should be '$' when you first open the terminal (means non-root user basically), and once you type su that should change to a '#' :)
I just did it from ADB via "adb shell" (immensely useful).
I completely agree with you, but with those new to android that might open up a huge can of worms regarding drivers. Phone not appearing under devices etc.
But yes, it's well worth getting set up with ADB
I tried that last night for the mic fix. The phone couldn't be detected so I tried the USBDeview.exe to remove the Phone but when I plugged it back in Windows found a drive for me so I couldn't substitute the one with the mic fix pack.
K. Any idea why rotating the phone to landscape should make the app crash? Its much easier to enter the correct text that way but the app crashes before I can get any text in on landscape.
Cheers Alfie, that was completely painless, now running the latest Amon Ra Recovery :)
No idea MarcLister, I just tried the 'standard' terminal emulator and it worked fine when switched to landscape, that's on 4.2.15.1...
lol
It's quite clear isn't it? I'm not insulting anyone. Just amuses me that my response to Khaans comment was immediately justified.
I still don't get it.
I said it's simple enough to do it through ADB without having to buy better terminal emulator - I assume the XDA thread was followed when installing the patch which tells how to apply it (and any others in a similar way).
Not because I didn't know what I was doing but because Windows didn't act in the way it was implied it would in the readme for the mic fix. :)
For the mic fix? Yes I did what it said and it just refused to work. :(
Hmm strange - sure ADB was installed using the correct USB driver?
Also, anyone noticed the wysies Contacts app changes? I love editing the contact categories now, instead of "Home" "Work" "Mobile" etc I have added custom ones like "Direct Dial" "Blackberry" and others :D
You have to install ADB? First I've heard of that. :p How do I go about doing that then mrk? ;)
Btw KHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAN. :D:cool:
Got it working. I used USBDeview again but made sure I interrupted the Windows driver process. I then went into Device Manager and found the ADB entry there and pointed it to the x64 driver in the mic_fix directory. Everything worked A-OK. :)
Just need to have another go at getting Amon Ra's recovery on there now. :D
To get adb working on my clean install of windows 7 (64bit) the other week i had to find a 64 bit driver for adb. The file location was buried deep within the adb thread on XDA. I have the free version of Better Terminal and that works fine so if I don't need to use adb I don't. It's not that I am afraid on command line interfaces, I'm not, my first PC was pre windows and DOS based, it's just that I like to do things the easiest way.
Something weird is up. I tried the new terminal app and it gives me an error when I do "mount -a" after doing an "su". Says something doesn't exist. Looks like the renaming of the recovery file to recovery.img, placing it in /data on the card and then doing a full reboot followed by a recovery reboot isn't working. I keep getting the old recovery GUI that.
Going to post in the Amon Ra thread and see what I get from there. :)
