Benefits of Win7 over XP
If you have a low spec PC then sticking with XP might be a better option if you're concerned with speed.
It would have to be really low spec. Windows 7 does very well on lower end hardware and minimal RAM. I know you know this from the VMs you and I have both run :D
I hope I'm not hijacking here. It's just I noticed someone (Neodite) mentioned Windows 8 here, but isn't Windows 7 really NT 6.1? (and Vista was NT 6.0)
It's all an evolution of the NT kernel, just like 2000 was NT5 and XP 5.1. I don't see what relevance that has though.
Microsoft already gave reasons why they did not use 7.0 for Windows 7 and instead used 6.1, from memory the stated reason was program compatability as some check this version number and by retaining it as 6.x it would cause less issues. Unfortunately the usual crowd jumped on this and called W7 a Vista service pack.
Calling it a Vista service pack is unfair, there are a lot of new (and good) features. OTOH it is much closer to Vista than Vista is to XP or XP is to 98/2000 (lets forget ME ever existed :) ). 'Vista 2' would be a better term, a Service Pack implies they should have given it free ot Vista users (and maybe they should have, but it's different enough to be it's own product IMO).
Obviously they couldn't all it 'Vista 2' though, that would have been a disaster. I think using a number was also a way of getting the tech crowd more on board, in general they/we always hated terms like 'XP' and 'Vista'.
XP is very similar to 2000 but very different to 98 (which used a totally different kernal). If someone says that 7 is just a service pack for vista then by that logic so is XP a SP for 2000. It simply doesn't hold water.
I made the move from XP to 7, I loved XP but can honestly say I am more than happy I made the move to 7.
Much more responsive, better memory management and have not noticed any decrease in game performance.
I like the fact that Microsoft engineering departments stuck to their guns are still versioned W7 as NT 6.1. The amount of pressure on them from the marketing/sales guys to name it NT 7.0 must have been immense.
TBH I doubt it even came up. It's such a non-issue.
I flinch when I turn my netbook on and see that green start button... shame I got the SSD version which can't take standard W7 installations. I should really shrink it down and get it on there.
If you've got anything better than a P4+1gb, you should be using Win7, it's as simple as that.
As a user experience, it's massively improved. The start menu search bar is almost enough of a reason to change in itself!
Windows key, "harry" and I'm a click away from my eBooks, my friend Harry's CV, my Harry Potter DVD rips, and the "Harry" episode of dexter.
I really want to switch to Windows 7, but not being able to get my Skarkoon Quick Sata Pro working via eSata is a bit of a blow. There's also no option to turn off the SPDIF electrically in the Realtek HD audio manager as there is in XP, but a lot of things are so much better.
The AHCI driver actually passes the HDD S.M.A.R.T data unlike in XP/MCE and my KWorld DVB-T100 card is utterly transformed in the media center, full interactive features, text and subtitles.
Unified drivers on the whole seem to work much better.
I absolutely love the driver support in W7. Usually the biggest pain of an XP install is hunting down and installing drivers and the million restarts. With 7 you can in most cases use it right away with its built-in drivers.
