i think the master servers are down as i cant log in. shame i took the day off to batter this today.
They are down until midday, so back up in roughly 45 minutes.
Ah gutted man... whats up with it?
i have no idea lol
it is making a beeping noise but i never heard such a beep before and can't identify if it is long or short O_O
guess i have to take everything out tonight and rebuild it completely. hope my mobo isn't dead![]()
TONIGHT IS THE FRIDAY NITE BEER NITE.... Get in there!
I'm out tonight and saturday so no pwning from me![]()
Mine used to Bleep when the GFX card wasn't sitting correctly. Just go thro each Component and double check its sitting right!
gutter!
DC can you do me a favour?
See if multiplay support is up and ask them how the fudge do you get the server Graphic to work... its doing my head now... i've tried everything and it will not work!
They'll say some rubbish about so many letters long etc, say you've tried everything and nothnig works.
I read earlier that it needs to be .PNG format and within the file and image size limitation they set , however it's supposed to be buggy even with those 2 things in place.
I have put my little banner on as the link so we will see if it works when the servers come back up![]()
yeah thats what i thought at first but problem was i haven't touched it and i even took it out yesterday and put it back in but still the same prob.
So ill try the other pci-e slot tonight or it might be a memory problem![]()
Nice1, give that a good try thisafternoon. when can you upload in a .PNG file? they told me is should be .jpg... Knubs!
Its sound like one of those 2, the long "buzzing" noice is a hardware problem?
The one I posted on the forums is a png i believe. I'm not 100% sure this banner will work until they fix the admin or generally fix clanforge and all the broken bits to the BFBC2 part.
I wouldn't put into the admin tool, paste this directly in to the config file at the end of bannerurl= http://img52.imageshack.us/i/tfubanner.png/]http://img52.imageshack.us/img52/8096/tfubanner.png.
That will stick, the admin tool just deletes it after shut down.
Yup PNG file.[/QUOTE]
I've already put it into the ClanForge config file , just waiting for the pop back up to give it a test :)
well it doesn't boot up anymore only makes the noise for 5-10secs and shuts itself down again.
I've already put it into the ClanForge config file , just waiting for the pop back up to give it a test![]()
Sorted!!!! cheers. hope it works, the server looks naked with out a banner![]()
Although I do think macarria's banner is far superior to mine!
