- 1 Mar 2010
I see. Thanks for clearing that up. With the 95C limit, it is unlikely it hit that over the stated period from peaks you posted earlier, to be honest. Solid effort, in any case.
Is that the i7 limiy 95c? does it auto shut down if it reaches that?
I can run constant folding (SMP) and vantage @ 4GHz at 1.25V cpu in bios..
So I think what I will aim for next is 3.8 at the lowest voltage as like you said the last 200 takes just that little more..
Twitch,
Sounds good. At 3.8, under burntest which is the hottest stress test I have found, my temps never exceeded mid/high 70's. Prime was low 70's. The 8 thread scientific code I have been running for days on end with all 4 cores at 90-100% never sees temps above 68. This is all on air, near silent, with hyperthreading. These i7's are so fast the extra 200 mhz isn't really worth it. Unless you want bragging rights I guess![]()
Have had one pass through here that did 4.14Ghz w H/T at 1.275v under a TRUE with sycthe juno 1600rpms and P6T SE with 6GB dominator ram. Really wished i could keep it but client was in next day for it and didn't have any 920s only i5sIts virtually silent at 3.6Ghz 1.1v (less in windows) as the fans are detuned to 5v, barely does 65C under intel burn and about 56C in prime. Was topping out at around 83C at 4.1Ghz with fans at full 1600rpm
How much temperature and performance difference does turning hyperthreading off have
Bought an i7 D0 retail here a few days ago.
On my H50 however, I get around 40 degrees idle and it shoots up to around 70 on stock settings!
Tried a Zalman Extreme cooler as well and various re-seating but the temps are about the same.
Whats wrong? I'm sad![]()
