Hi
A friend of mine has a 7750 and it sounds like a plane taking off, he isnt technical at all but I assured him there must be something wrong.
After running speed fan I noticed the CPU temp was 45 idle and the fan is going 5000 RPM+ with the case on, the cooler whilst not being the best is definately better than the stock, its a decent sized copper heat sink and a DC Brushless AFC0812DD fan.
I've taken it all apart cleaned it and put it all back together but still the same problem. I've tried cool and quiet, but all this seems to do is run the fan faster to keep the temps down.
I don't really know what else to try. The only thing I can think of is suggesting a new heat sink and fan but this one seems to look fairly good. I do know the heatsink and fan came off and older system so possibly it is outdated, are the new cpus much hotter than the previous ones? Or possibly a quieter fan would be an option.
Thanks
Thanks
