Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
M24:
Short range <=8m: 100 Bodyshot, 325 Headshot, 125 Bodyshot with Magnum ammo, 406 Headshot with magnum ammo
Long Range >=25m: 75 Bodyshot, 244 Headshot, 94 Bodyshot MGA, 305 Headshot MGA.
GOL:
SR <=8m: Same as M24
LR >=25m: 70 BS, 228 HS, 88 BS MGA, 286 HS MGA
M95:
SR <=12m: 100 BS, 210 HS, 125 BS MGA, 262 HS MGA
LR >=40m: 79 BS, 166 HS, 99 BS MGA, 208 HS MGA
Okay...So what about medium range?
Thank god , no shotgun fixes! :D
Boo, no shotgun fixes :(
It's fun n'all dropping on slugs and MGM and head-shotting folk 300m away but really they need hit registry to be improved, sometimes you can just be stood 3m from someone and only 1/4 pump action shots will actually register.
GOL Short range is 8m, Long range is 25m. Base damage at 8m or less is 100, base damage at 25m or more is 70. The damage curve drops evenly between the two ranges and damage values. So at about 16 meters, it does about 85 damage for a bodyshot with no magnum ammo.
I like how they've got to work on the important things... like balancing the medic and sorting out hitboxes. Oh wait no they worked on ways to make K/D ratio display more accurately :rolleyes:
M24:
GOL:
M95:
Nice one, cheers.... quite odd to see the GOL is the worst for damage at long range. I'm guessing there's no way to bump the M95 long range body shot with magnum ammo to be a one-shot?
Fixes said:
Change: Server browser now defaults to list via Ping first
Well that's not much good, considering I can't even see the pings :P
I think the damage values for the M95 were deliberately set so you can't 1 hit kill with a bodyshot at all at long range. You can one hit kill with a bodyshot at up to 40m though. Try taking it with a red dot sight/4x zoom.
Also, for ping list in browser run with admin privileges. Source: http://blogs.battlefield.ea.com/
I can If is run as Administrator. goto game folder right click the executable, do properties select administrator. then pings show all the time.
M24:
GOL:
M95:
Who the hell is going to be using a sniper rifle at under 8 metres? :D
I tried but when you miss it all goes **** up with the 2+s reload time. :D
How do you lock onto vehicals with a rocket launcher? Onlly think I know how to do is zoom in with it and manualy shoot lol. Everytime I'm in a tank I always hear the mille lock siron go off...
Too right - same scenrio happened to me last night. Emptied 6 shells into someone at 2m, and then they ran away leaving me perplexed! Did sound good in the confines of a container.
I play close range recon with the M95 (I used the M24 until I unlocked it). I bodyshot and dead at that range is great against a squad, because you can kill one with that, 1-2 with the 1911 and then another 1-2 with the knife. It's also good if you happen to run into a sneaky guy in your base.
Shoot it with a tracer dart first or get someone else to. When you zoom with your RPG, you should see a small red box on the tank (even if you can't see the tank). Aim at this box until you see a range appear underneath it, then aim up and fire.
Once someone has placed a traced dart on the vehicle, an orange box will appear when you look down the sights of the first 2 launchers. Wait until you see the distance has been calculated, then fire and forget.
