So after a couple of years my Macbook Pro's battery isn't what it used to be. I bought a 'genuine' new battery off a reputable UK seller on the bay and this arrives.
I think it might be fake - the aluminium panel on the back is punched and not laser cut like on my old one. Also the writing on the back is not as well etched and is also spelt a bit weirdly - You can't really see as well in the picture but notice how it says Rechargeable Battery, and also JaPan.
Do you guys agree?
It seems to work ok in my Laptop and gives the following info in System Profiler:
Now I don't want to just start having a go at the seller without any concrete evidence. Is there anyway I can check the serial number on the net to see if it is genuine?
Cheers
Hamish
Do you guys agree?
Code:
Model Information:
Manufacturer: Sony
Device name: ASMB012
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0102
Hardware Revision: 0300
Cell Revision: 0200
Charge Information:
Charge remaining (mAh): 3854
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 5443
Health Information:
Cycle count: 1
Condition: Normal
Battery Installed: Yes
Amperage (mA): 1827
Voltage (mV): 12480
Cheers
Hamish
Just send him a polite mail, he'll prob send you a new one, at least I would.
