thermaltake level 10
28 Nov 2004
im thinking about getting a thermaltake level 10 case.
using my asus rampage 2 extreme mobo.
buying a corsair h50 cooler. for cpu. i7920 do.
and for my 5870 putting a slim 140mm rad @ the front.
so 2 seperate loops. the pump im going to use aXSPC X2O 450 Pump with Acrylic Reservoir. do u think i could put that lot inside the case.
thx in response.
Corsair obsidian with proper water cooling would be even better for that much money.
Antec P183 / P193 with air cooling if you dont want to go water.
the h50 doesnt work well in the level 10
we use a megahalem in our Divinity system. that is the best route to go down if you are keeping the level 10
I think its due to how comparmented the case is, it wouldnt have much space to hook up the CPU sink and radiator fan.
The Megahalem is a brilliant cooler anyway.
thank u for that imformation. ill try the megahalem instead.
but do u think the slim 140 rad would work on a 5870.
using the right intake 140 fan and a small pumpres.
just had a look @ the megahalem cooler is this the best air cooler i could buy or could i get better.
