have you tried different OC'in apps? dont see why 2 screens should be a problem. Theres quite a few updates to multi screen setups so they might just be stating the main updates your problem may still be covered.
One way to check.
Use a download manager, change 10.2 to 10.3
Powerplay messes up two screens as they clock too low, using eyefinity fixes the solution (I.E, it appears less clocks are needed for eyefinity than extension).
Have you tried overclocking with just 1 screen? if it does then you know its not the card and then can put it down to the driver/software issues.
That card go to at least 900mhz core.
I fixed that skippy by changing 2d clocks in bios to 400/1200. It flickers maybe once slightly every 5 mins now, however bc2 will flicker a little bit so i just disable the 2nd screen if im gaming.
And flashing the 3d clocks up
Iv never had any performance issues with any of the drivers............
I feel so left out by not being excited about this driveri will download and see what the fuss is about
ill give it till 12. Iv not previewed the 10.3 so will i notice a increase in fps and smoothness ? because iv never had any problems before![]()
