Done some overclocking and managed to get this below stable in prime, this test here around 1 hour 20 in and intel burn test, volts are are they ok ?
Cpu 1.2935
QPI 1.23
PCH 1.12
PLL 1.88
[/IMG]
Very good vcore compared to my chip to be 4GHz stable.
Which PRIME test were you running btw?
Mine will fail a 'Blend' test after a few minutes at that voltage... Can't say I touched any other voltages yet though so maybe that's the reason.
Is your overclock with LLC enabled?
The Gigabyte GA-P55-US3L considered a decent budget overclocking board? Just after something to tide me over til the Hex cores become more mainstream/cheaper
cheers
Si
I had 1 for a few days clocked very well...but got unlucky and encountered a problem which could have occurred from the amount of pressure needed to seat the ram and the faffing about with it
Problem being only able to boot with 1 stick then add the other...after a cmos reset rapid beeps had to remove ram then insert 1 stick to boot up again
After few days slot did not recognise 1 stick anymore and had to rma board.
Obviously unlucky but when it was working it was good.[email protected]
It's a Cooler Master Hyper 212 Plus with dual fans... push/pullNice results vocch, out of interest what cooler? Seems good for the dosh
