As above it will depend on the memory controller, not the RAM itself (a common misconception), as to whether you'll get away with it or not. Success or failure will vary with different motherboards. Might be worth trying since it does give a performance increase with multi-channel DDR2/3 systems, albeit a very small one, usually nothing more than a few percent in real world type testing. More reliable sources do not recommend 1T if you are overclocking. Since I run my RAM at stock I've got the command rate set to 1T without any problems but if your mobo / OC isn't happy with it, then it's no great loss at all. A stable OC at 2T will possibly provide more of a real world gain.
