Driclor Vs Odaban
These look a bit suspect to me.
The sweatblock pads use 13% Aluminium chloride as their active ingredient vs 20% for Odaban/Driclor. With the latter you have to apply frequently at the start so I don't see how sweatblock can claim a single weekly application will suffice.
You would be better off buying Odaban and spraying it onto a cotton wool pad. This is what I do and a £5 bottle lasts me 6 months.
if they dont work then that will be my next option, tried dricolor in the past and it worked for a bit then had no effect
the reason i ordered them is i saw a review of them in a womens mag so thought why not i'll give them a go
I read that this can happen to people who have bought the product but used to much to quick. you need to start off with small applications and slowly build up. then just use a few times a week.
it said that if you use to much to quick then it stops the sweating but "the dams burst" so to speak and your back to square one.
anyway i've just orded some odaban from amazon of all places lol.
i shall report back. possibly with a new thread in a couple of weeks.
