- 23 Dec 2009
- RG8 9
Meh I think mine has just borked.
Meh I think mine has just borked.![]()
Ok fixed it, wedged it open with a blade, the cam is fixed in with glue but theres a little give.
My initial darkness tests are not coming back well, in fact I'd say this is almost useless in the dark. Looks like it'll be lights on for the voyeurs.
As has already been mentioned, plug the cam in and navigate to the root folder, drop the tag.txt file there, then unplug, power off and back on again.
You will know if it has worked as the tag.txt file will disappear from the root folder.
When you say 'ROOT' folder, it seems like mine doesn't have one. I just formatted the card and off I go.
Thats all mine says at the moment but its still charging so I can't properly test it yet.
Got mine today and realised it a #3
Still working out how to use it though lol![]()
ordered along with a 4gb microSD from OCuk. can't wait
If people are starting to receive these, where is all the cool experimental footage!?!
