Hey chaps.
Apologies in the delay of my screenshots etc. Halfway overclocking yesterday my brain just fried and I really had to go to sleep. Plus I swear my missus had aggro eyes when she woke up and found me glued to the system.
Played around with the clocks a little here and there. Suddenly hit me that I might not be doing it right.
Here's a list of the programs I used.
XFX Overvolt Tool
CPU Z
GPU Z
Furmark 1.6
ATI Catalyst
Issues so far :
Screen stuttering on my displays when I'm surfing the net. I'll be upping my 2d clocks later when I get home from work.
Computer crashed a couple of times when I rebooted though I then later found out because of my clock speed 950/1300 I have to quickly rank up the voltages in the overvolt tool as soon as I booted up otherwise the PC will crash. Voltages used were maxed out on my overvolt tool. So I had 1.1625 and 1.15 (max) on the XFX overvolt tool.
Temperature wise, the card idle's at about 29 degree's. When it was loaded at those speeds it went up to about 49 degree's after 20 minutes with Furmark.
Just in case I mucked up because I was playing with it from 1 a.m till 9 a.m, I resetted the clocks back to 725/1000.
Unfortunately when I woke up, I was playing BFC2 and Dragons Age the whole day. I couldn't move from my seat! No problems whatsoever. No crashing no stuttering. Haven't got fraps installed yet but It was very smooth with all settings ranked up.
I guess my aim tonight is to try and get some stability tests in and properly overclock the card.
I plan to use
MSI Afterburner
CpuZ
Gpuz
RealTemp
Furmark
Vantage (though I have no idea where to get a proper version as the one I downloaded only lets me install a trial for a one off test)
Mark 06
Now I haven't used MSI Afterburner before. And everytime I look at it, it seems theres no way to set up the voltages as it always seems to be zero on screenshots? Or am I being a fool?. Having said that, I have no idea on what sort of voltages I need to overclock the card. So I just maxed it out using the XFX overvoltage tool anyway.
Will post some updates tonight.
How are the rest of you getting on so far?
Sam
